Xigmatec Asgard - audio socket panel replacement
14 Feb 2003
UK
Part of a headphone plug broke off in the green headphone socket of my Xigmatec Asgard case. I have tried a couple of the toothpick / straw and superglue tricks to remove it but to no avail.
I use the socket a lot and now need to get a replacement panel (3.5 inch) with headphone, mic and a couple of USB sockets. What would you recommend? Must be available through Overclockers UK of course!
Ta.
That will do, thanks!
I don't use the PC for its audio quality - I have hi-fi for that - so the front panel is fine for what I need. Funny though I did look in case accessories but did not spot it. Must be going blind as well as deaf!
