Xigmatek AIO Liquid Cooler
10 Jun 2003
Basically it bolts straight to your CPU and thats it . Anyone used one of these or something like it ? Seems a good idea but how quiet or effective it would be I dunno ?? :confused:
Quote : The all-in-one liquid cooling system combines all of the key components we need into an integrative one,without tedious assemblage, users can have cooling ability with high capacity and efficiency. Combines with radiator, pump, water block and cooling fan, the looks of all-in-one liquid cooling system is just like a single cooler which has the same installation steps with others.XIGMATEK AIO-S80DP is powerful, performing similar to other internal or external liquid cooling systems. An all-in-one liquid cooling system design provides quick and easy installation. It combines dual 80x80mm radiator, dual tank, 80x80x25mm PWM ball bearing fan inside, 12V DC pump and copper water block.
Cheers for that ;)
On reading that its not what I thought it was , I had visions of an AIO watercooling kit but its basically just a sit on cooler , ah well
It would appear not a bad idea but not quite there, needs modding :p
