Hi Everyone quick questions concerning a heat sink:
I want to order a:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-XG&groupid=2362&catid=1572
and put a:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-013-XG&tool=5
inside it. The case says it fits up to 160mm tall side-blow tower coolers and the cooler states its 159mms in height so by that logic it should fit?
I wondered if anyone had any experience with both to say for certain? or if anyone could recommend a smaller cooler which was as quiet for the same price or less.
Thanks Guys
I want to order a:
and put a:
Thanks Guys
