Xigmatek Elysium, Aurora red
28 Nov 2011
Cumbria
just finished updating my wc system, have gone for Mayhem Aurora Tharsis red.
will add some more pics tomorrow now fluid is in
Isn't this the only case that will take 420mm radiators without modification (excluding silverstone and some other very expensive cases not sold here) ?
Is it solidly built and does it have a good weight? Even if so, the elysium is meant for E-ATX and dual sockets which makes it undesirable.
The NZXT 810 can fit some but not all and seems cheaply built.
Hi cobbly123,
I love the look of the case :).How are you finding it is it nosily,what are the fans like?
I'm thinking about getting this case or a 800D.I've you got any pic's of the fount of the case
Thanks again mate
Cheers
the fans that come with it are realy quiet, the only reason i changed was for the red leds. Will get some more pics taken tonight and add them :) the build quality is brilliant. Its not a case to carry around anywere as they are very heavy. The wheels make it ideal to shove around
Jezz that mobo looks so small in that :p glad you put the res there or we would be looking a gromits :P
lovely machine, Enjoy Op
P.S. get a better camera :p
Cheers
Cool thanks mate :)
If you get a case and it doesnt have the grommet for the second cpu hole, if you email xigmatek direct they will send one out f.o.c :)
Mine was an early case and didnt have one but they sorted it np. Brilliant aftersales service :)
These are brilliant cases for watercooling with so many good features. I have a 120.3 in the top and a 120.2 in the drive bays and theres still plenty of room inside.
