** Xigmatek ** IN STOCK
Xigmatek Red Scorpion S1283 CPU Cooler (Socket 754/939/940/AM2/LGA775)
Inherited best product in the market, HDT-S1283, but also with Nickel Heat-pipe, transparent colorful and 4pcs white LED lights on fan, RED SCORPION is not only an outstanding performing product but also looks like art collection. With Anti-vibration rubber, spoiler design and Push-pin/Clip for INTEL & AMD, RED SCORPION offers friendly, easy to install, reliable and powerful performance for users.
- Dimensions: 120 x 159 x 50mm (W x H x D)
- Material: Aluminium Alloy
- Fan Speed: 800 - 1500 RPM
- Air Flow: 61.3 CFM
- Noise Level: 15 - 23 dBA
- Orange Fan
- 4 x White LED
- 4 pin PWM connector
Only £27.99 inc VAT
BUY NOW
Xigmatek Thor's Hammer S126384 Heatpipe Cooler (Socket AM2/AM3/LGA 775/1366)
Thor's Hammer is signalizing the strength and efficiency of our today's launched cooler for your overheating Core i7 CPU's. With its 4x8mm Heat-pipes on the H.D.T. Base and the 3x6mm Heat-pipes on the 2nd layer, it is launched as a “World Exclusive Technology Cooler” but also outstanding and great performance. Not only persuades the enthusiasts and worldwide users by performance, but Thor's Hammer is also attractive by its unique and shiny black dedicated.
- H.D.T. (Heat-pipe direct touch) technology.
- Double layer HDT & Double performance.
- Plating Black-Nickel on whole body.
- 4pcs ?8mm + 3pcs ?6mm high performance heat-pipes.
- 2 fin type combination provides efficient air flow.
- Passive cooler design with option of fan installed.
- Anti-vibration rubbers prevent vibration and absorb noise.
- Spring-Screw + Universal (LGA775/1366) Back plate.
- Ready for Intel Core i7 CPU.
- 120(W) x 90(H) x 160(D) mm
- 800g
Only £44.99 inc VAT.
BUY NOW
Xigmatek Cobra D984 CPU Cooler (Socket 754/939/940/AM2/LGA775)
Cobra-the Queen of Snakes, powerful and moving fast. Cobra D984 is a high end cooler and transfers the heat rapidly. Instead of a cooper base, Cobra D984 is designed with both Patented ”Fin connected to HDT base” and ”H.D.T. Technology” to provide efficient and outstanding cooling performance. Cobra D984, like other H.D.T. series coolers, is with the advantage of light weight, easy installation, anti-vibration, performance and user friendly.
- Dimensions: 92 x 92 x 25mm (W x H x D)
- Fan Speed: 1200-2800 RPM
- Air Flow: 39-54 CFM
- Noise Level: 20-28 dBA
- 4 Pin PWM Connector
Only £29.99 inc VAT.
BUY NOW
Start stocking their fans!
I am very tempted to get a Thors Hammer. Partly because it's called Thors Hammer and partly because my Sunbeam is an unsightly horrible peice of crap in my beautiful Fortress.
as said stock there fans!!!!!!!
& sadly as for there heatsinks they have a tendency to forget about AMD & just give a shoddy retention bracket ;/
I bought the Dark Knight from elsewhere a few months back and it's one of the best looking and performing CPU coolers out there, especially as an alternative to the likes of the TRUE Black. It's cheaper and performs just as good, if not, even better in some scenarios.
Still, it is great that OcUK are finally stocking Xigmatek products. And yes like mentioned before, please also stock their fans. The red fin/white LED fan from the Red Scorpion is one of the nicest looking fans out there and I have been dying to get those for a long time.
please ocuk listen to our requests and start stocking in their 120mm red fin white led fans....i would definitely order atleast 10 the day you get them in stock:(
