Xigmatek Midgard Case Deal! Under £20!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
What an epic deal! The Xigmatek midgard is now only £19.99 for a great case this price is amazing. The stock is strictly limited so first come first served! You snooze, you loose! Early bird catches the worm! Early to bed, early to rise! The cup is half full, not half empty! Like Nike say "Just Do It". That's the way the cookie crumbles!
Xigmatek Midgard Midi Tower - White @ £19.99 inc VAT
Midgard - home of mankind and protected by Thor, God of thunder, and his hammer. Signalizing the strength of diviness and mercy, but at the same time proprietaring the hardware you built in. Combined design and features such as white coated SECC and steel mesh are spotlighting your chassis when your system is built. Furthermore this chassis is supplied with 2 x 120mm pre installed fans (orange blade and black, transparent housings), but another 5 fans can be mounted in different areas for best possible airflow. 5 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5" and 2.5" HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners.
- Material: Steel Chassis
- Anti Vibration rubber on PSU compartment
- 5.25" External x 5 (One bay with 5.25" to 3.5" adapter, tool-free)
- 3.5" Internal x 5 (Tool-free)
- Cooling: Front Fan 120mm white LED with orange blades x 1, Rear Fan: 120mm white LED with orange blades x 1 (Preinstalled), Side Fan: 80/90/120/140mm fan x 1 (optional) 120/140mm fan x 1 (optional), Bottom Fan: 120/140mm fan x 1 (optional), Top Fan: 120/140mm fan x 2(optional),
- I/O Port: USB2.0 x 2, e-SATA x 1, Audio x 2
- Dimensions: 206 x 510 x 477 mm
Was £54.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Stock will be arriving tomorrow!
