Xigmatek push-pin replacement
22 Dec 2010
Hi,
two of the push-pins for my Xigmatek HDT-S963/1283 recently broke after moving house with the PC.
I don't want to get a screw down solution as I'd have to take the mobo off, even though I ackowledge that it's probably a better solution.
Can someon tell me if I can buy the push-pins somewhere separately? I'm in Gibraltar so can't just drop into a store in London..
Thanks for your help in advance!
Yes they can be bought, but unfortunately OCUK aren't stocking them.
Competitors do, but im not going to link to their sites.
Google it.
