So when I go home from uni this Christmas I want to have a play around with some of my old kit. I have an AMD 64 3500+ 1Gb ddr1 ram, an Asus an8 SLi premium I think that’s what the mobo is called and a 200Gb hard drive.
I have no case, power supply. I have an x850 xt would this be ok to drive HD films? or would it be better to get somthing else? I was thinking about making a budget HTPC. Since I’m a student I don’t have much cash so what’s new
i'm thinking £100 max but if possible i would like to spend less.
Anyone got some ideas for a small case or can you really not get a small case for an atx mobo? If so I can sell my mobo and buy a cheap 2nd hand matx
to fit into a small case. I don’t think I’m going to buy a HD or blue ray drive so I can just run the HD content off the hard drive.
i'm thinking £100 max but if possible i would like to spend less.Anyone got some ideas for a small case or can you really not get a small case for an atx mobo? If so I can sell my mobo and buy a cheap 2nd hand matx
