XML and CDATA
7 Jul 2003
oh I do like to be beside the seaside
Which is these is the correct use of CDATA in XML?
Code:
<![CDATA[<AddressLine1>1 Arcacia Avenue</AddressLine1>]]>
or
Code:
<AddressLine1><![CDATA[1 Arcacia Avenue]]></AddressLine1>
I'm thinking it's the 2nd one as the tags are outside of the CDATA, whereas in the first one the tags are inside and so will just be treated as text
Thanks.
CDATA inside the tags.
Technically both are valid, it depends what you want to achieve - inside the tags is more common though.
