Hi Guys, quick question which my be simple to yous.
I have a xml file containing data and I am using php to output it into a table.
I have it working except for outputting the id value.
For example I have a list of memos in the xml file and each memo has an id.
Here is the part of the code which I don't think is correct:
As said all the other parts output to the table except the 'id'. Tried doing '@id' as you would in xsl but didn't work
Cheers
Code:
foreach($memos->childNodes as $memo) {
$memoIDNode=$memo->getAttribute('id');
$memoTitleNode=$memo->childNodes->item(0);
$memoSenderNode=$memo->childNodes->item(1);
$memoRecipientNode=$memo->childNodes->item(2);
Cheers
