Hiya. I have an XML document that has visits and pageviews data for each country. Im having problems trying to retrieve the visits data when the country is United Kingdom.
The XML is:
Heres the code im using (classic asp). The logic im using is finding the dimension with a value of united kingdom, then return to the parent node and get the visits data.
The error im getting:
Any help would be greatly appreciated. Thanks
The XML is:
Code:
<feed>
<entry>
<dxp:dimension name='ga:country' value='United Kingdom'/>
<dxp:metric confidenceInterval='0.0' name='ga:visits' type='integer' value='7348'/>
<dxp:metric confidenceInterval='0.0' name='ga:pageviews' type='integer' value='25309'/>
</entry>
<entry>
<dxp:dimension name='ga:country' value='Ireland'/>
<dxp:metric confidenceInterval='0.0' name='ga:visits' type='integer' value='73/>
<dxp:metric confidenceInterval='0.0' name='ga:pageviews' type='integer' value='25'/>
</entry>
</feed>
Code:
totalUKVisits = xml.selectSingleNode("//feed/entry/dxp:dimension[@value='United Kingdom']/../dxp:metric[@name='ga:visits']/@value").text
Code:
msxml3.dll error '80004005'
.. may not appear to the right of / or // or be used with |. //feed/entry/dxp:dimension[@value='United Kingdom']/-->..<--/dxp:metric[@name='ga:visits']/@value
