XML reading empty tags with no whitespace - python
1 Mar 2003
Cotham, Bristol
I have an issue with parsing the following xml file correctly
Code:
<?xml version="1.0" encoding="UTF-8"?>
<!--Sample XML file generated by XML Spy v4.1 U (http://www.xmlspy.com)-->
<xml xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="director_param.xsd">
	<Header hdr_filename="345678.par" hdr_filetype="Director Parameters"></Header>
	<Content>
		<JOB>
			<CUSTOMER></CUSTOMER>
			<DEPARTMENT></DEPARTMENT>
			<DOCUMENT_TYPE></DOCUMENT_TYPE>
			<JOB_RECEIVED_DATE></JOB_RECEIVED_DATE>
			<SLA_DUE_DATE></SLA_DUE_DATE>
			<SLA_WARNING_OFFSET></SLA_WARNING_OFFSET>
		</JOB>
	</Content>
</xml>
This is the test python code. I'm using XMLParser as I have some bespoke parsing behaviour I need to implement for start, data and end. I am aware of standard ElementTree functionality but it's not appropriate for my scenario.
Code:
import xml.etree.ElementTree as ET
class Parser:
    def __init__(self):
        self._tag_name = ""
        self._section_tagdata = {}
    def start(self, tag, attrs):
        self._tag_name = str(tag).encode('ascii','ignore')
    def end(self, tag):
        pass
    def data(self, data):
        if '\t' not in data and '\n' not in data:
            self._section_tagdata[self._tag_name] = data.encode('ascii','ignore')
    def close(self):
       pass
target = Parser()
parser = ET.XMLParser(target=target)
xmlFile = open('O:/clients/concepts/workflow/test.xml','rbU')
xml = ""
for line in xmlFile:
    xml += line
parser.feed(xml)
parser.close()
for k,v in target._section_tagdata.iteritems():
    print k,v
In this scenario there is no output from the print loop. What seems to be happening is in cases where you have xml data like this.
Code:
\t\t\t<CUSTOMER></CUSTOMER>\r\n
\t\t\t<DEPARTMENT></DEPARTMENT>\r\n
When it tries to read the data for the <CUSTOMER> tag it takes the data as being \r\n\t\t\t. If however the xml file is formatted so that if there's no data for the tag there's a whitespace character like so.
Code:
	<Content>
		<JOB>
			<CUSTOMER> </CUSTOMER>
			<DEPARTMENT> </DEPARTMENT>
			<DOCUMENT_TYPE> </DOCUMENT_TYPE>
			<JOB_RECEIVED_DATE> </JOB_RECEIVED_DATE>
			<SLA_DUE_DATE> </SLA_DUE_DATE>
			<SLA_WARNING_OFFSET> </SLA_WARNING_OFFSET>
		</JOB>
	</Content>
Then the output for the above code is
Code:
CUSTOMER
SLA_DUE_DATE
JOB_RECEIVED_DATE
SLA_WARNING_OFFSET
DEPARTMENT
DOCUMENT_TYPE
Which is correct. Other than altering the format of my xml, what can I do to the code to accommodate it.
Ok fixed it, it was quite a simple change in the end.
Code:
        else:
            if self._tag_name not in self._section_tagdata:
                self._section_tagdata[self._tag_name] = ""
