I am thinking of putting 2 x Corsair Dominator 1600MHz kits on to an X58 board (Asus P6T). I want to get the full 12GB supported by the board.
2 questions:
1) XMP & Multi-DIMMs per channel
I have seen several statements in mobo manuals and on the Intel site stating that you should only use one DIMM per channel if using XMP.
Am I correct in interpretting this as: if you have XMP turned on in your BIOS you should only use one DIMM per channel, but if you have it turned off you can have several.
Or do I need to avoid XMP memory all together if I want to use all of my DIMM slots?
2) Filling your DIMM slots
From a number of sources it seems that if I fill all of my DIMM slots that I will probably need to either downclock from 1600MHz to 1333MHz or, if I want to hit 1600MHz, raise the VDIMM and relax the timings.
Would the same hold true if I used 1333 native memory (i.e. would I either have to downclock it to 1066 or raise the VDIMM and relax timings), or should the mobo/chipset support 6 sticks at what is listed as it's stock rating?
Thanks
--Gigo
2 questions:
Thanks
--Gigo
