xmp question x570 Master mb
30 May 2012
Emsworth
Heyo
So I bought the 8pack 16gb 4133Mhz ram kit and doubled it to 32gb.
I found that the xmp only works when using 2 sticks at 16gb while it fails when using all 4 sticks at 32gb.
So I'm thinking as I see that everything is optimal at 3600Mhz, if I bought the 8pack 2 x 16gb kits would I be able to use all 4 sticks on xmp? Or would it fail like this one?
Should always buy all your ram in one kit ideally
Even adding another lot of the same ram later while it usually works
It's not 100% guaranteed to
That said you are aiming at a pretty high speed for 4 modules
It may take manual tweaking rather than xmp
Never used ram that fast though
So even though my x570 auros ultra is almost the same as your board my 32gb~ 4 x 8gb is too slow to test for you as I re~used my 3000mhz to keep costs down for my new build
