XMP updating?
18 Apr 2010
Afternoon All,
I recently have had a new case and updated my BIOS to V1.10, there is now also a XMP profile V1.3, updating the BIOS, did not update the XMP version.
Would someone kindly enlighten me as to where the files are attainable, and do I update the XMP the same method as updating the BIOS via a USB memory stick. Thanks kindly for any help
If the BIOS update didn't change the supported XMP version then it isn't going to happen, you can't update it separately.
Is there a particular problem using your RAM?
There is no problem as far as I can tell, I was just wondering how much gaming performance it would hinder. Also with me using the Turbo overclock function on BIOS to 4.4GHz I was wondering if it was affecting anything
As long as your RAM is configured correctly in the BIOS then you wouldn't see any difference.
If you're not sure then upload an image of the Memory tab from CPU-Z.
