Can someone please help me with this…
I’ve upgrade my main rig, and I’ve been left with a pile of parts that I’m now building into a PC to be sold, however I’ve pretty much ran into a problem…
The memory from the old system was Corsair (TWIN2X2048-6400) XMS2-6400 2048MB 5-5-5-12 2X240 DIMM Black XMS2 Heat Spreader
He wants 4GB, luck would have i had already purchased what I felt was the same type of Corsair XMS2 memory for a upgrade I never did. Its listed as Corsair 2GB (2x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit Non-ECC Unbuffered CL5
I remember some years ago when I put the first 2GB into the ASUS P5B Deluxe with the E6600 Core 2 Duo it blue screen Windows XP within 10mins everytime… Corsair recommended upping the vaults in the BIOS to 2.5v and I did just that… Cured the problem and ran for me like this for three years…
I purchased the above upgrade as like I said, they wanted the full 4GB (family member wants a new, reasonable spec PC) and now I’ve got it up and running its doing the same as before, blue screening the OS even with voltage set to 2.5v. I read the back of the packet for the new memory it said 1.9v, so I set it to 1.9v and still the same…
Can someone confirm that the upgrade I got will work with the existing memory, if at all? System works fine with 2.5v for the older memory, or works fine with the newer memory BIOS set to auto, but not together…
Are they not the same memory modules? Thought they were, both are XMS2 DDR2 800Mhz and both look identical.. Black heat spreader, everything looks the same… The only thing I’ve not done is set the timings to 5-5-12 as like the existing memory using 2.5v, maybe that’ll cure the fault?
Thanks..
Thanks..
