Xms3 timings
Dram frequency 669.7 mhz
Your memory is only running at 1333 (2 x 669.7) which explains why you're capable of running such tight timings.
Go into the BIOS and set the memory timings, frequency and voltages manually (try 1.5V, 1600MHz and 9 9 9 24 - if you have problems up the voltage to 1.55v).
Once stable - try and experiment with the timings (if you want to - there wont be much benefit in day to day usage).
