XMS3 Timings
11 Apr 2011
Somerset
I bought an OcUK overclocked bundle but decided to play around with the settings myself a while back and during the process reset all the settings to default values. I've just noticed that CPU-Z reports my ram timings as 11 11 11 29 when the XMS3 product page states the latancies as 9 9 9 24. Is it a simple matter of finding the settings in the BIOS and changing them, or is this normal? :)
Yes change the settings in the BIOS.
If you reset the BIOS the memory is probably running at 1333MHz so you'll need to change that as well.
