Xonar D1 problems win7 x64
3 Apr 2003
Swear i have had nothing but problems with this card since i first bought it a year or two ago.
Just had to format my pc, had driver files etc all backed up on another drive. Installed the sound card but does not work, in device manager it shows up as having a problem, and then says Device cannot start (code 10) or something along those lines, at work now so cant elaborate.
Worked fine before the format. Have tried multiple different drivers including the unified ones but none work, just says that same error in device manager and cannot start the xonar panel. Onboard sound is disabled etc.
Its windows 7 x64, but as i say has been working fine before the format. Can anyone offer any input or suggestions as i spent hours messing with it last night and ended up having to turn the onboard sound back on just to watch a program.
Cheers
