8 Jun 2013 at 11:17 #1 supergt supergt Associate Joined 22 Jun 2005 Posts 1,023 Hi there, just a quick question. Would a Xonar D2 be compatible with my speakers ( logitech z5500 ) or would I need an adapter to connect them? Cheers
8 Jun 2013 at 11:55 #2 Marsman Marsman Soldato Joined 18 Oct 2009 Posts 11,174 Yes they are compatible. You can either connect using the analogue green/orange/black 3.5mm jack leads, or use coaxial/optical.
