The front 3.5mm jack on my case has broken unfortunately.
My problem is that when I plug my headphones into the sound card it's self, I get no sound at all. When I try plugging into the motherboards 3.5mm jack I only get onboard sound.
It's seems a bit odd to me
Do any of you know how to get the motherboard headphone socket to use my sound card? or failing that, why the ports on the back of the card it's self would not be working?
Thank you!
Thank you!
