- 8 Sep 2009
Hi All,
I'm looking for some help setting up my recently purchased Asus Xonar DX 7.1 Soundcard.
Equipment in use:
HTPC running Windows 7 with XBMC as primary program for playing all movies etc.
Panasonic 5.1 Home Cinema System connected to pc via Optical (unit can only decode DD not DTS via the optical)
I have everything connected up and getting sound from all speakers but i could do with a few pointers as to the correct settings for using Dolby Digital Live. I stumbled across the following page which makes me wonder if i am recieving proper DD from sources which already contain DD. http://www.mce-pro.co.uk/articles/asus-xonar-dx-and-the-dolby-digital-dilemma-our-solution/
I basically want everything to be passed to my panasonic system as DD as it cant decode DTS, sources are mainly MKV rips of blu-rays which i guess are a mixture of DTS or DD AC3 5.1
There is also settings in XBMC to set audio device to analog or digital....its all rather confusing!
Any help would be much appreciated!
Equipment in use:
