Xonar Essence STX problem with mic
4 Dec 2012
I've had this problem for awhile now and I need it sorting, I use the sennheiser game one headset with this sound card its amazing but my problem is the mic I use the stereo adapter jack to connect the headset to the sound card it only came with one so bought another for the mic.
The problem is when I speak on a voip as soon as I speak through the mic I get this screeching noise that gets louder and louder then it will fade completely away until I speak again and it repeats the same thing, I changed the jacks over but the mic still does the same thing, anybody know what the problem is?
Settings I use in Xonar Audio Center
Audio Channel - 2 channels
Sample Rate - PCM 48KHz
Analog Out - Headphones
Dolby Headphones ticked - Reference Room - DH-1
Thanks, SpringY
try going into the xonar software and advanced on mixer? on the microphone side and disable front panel audio, see if this makes a difference.
