Xonar Line-in recording ? :x
29 Dec 2003
UK
Ive just got an Asus Xonar and its superb in games/music.
I want to be able to record a mix from my turntables to the line in like i have done many times before with my old creative live and since then onboard soundcards.
So i hook up the line in and I can hear it through my pc speakers, nice and loud, so far so good.
I am then using Total recorder to try and record, if i choose line-in as the source and run a test recording its very quiet , ( 5% of decibel bar) and it says it has failed and i should try another source. This doesnt make sense as the sound through my speakers is as loud as any mp3 i could play. The line level in is on full in the Xonar recording menu.
Anyway, ive then tried Stereo-mix as the source, it records nice and loud on the decibel meter but and as soon as the test recording starts the sound dissapears from my speakers :confused:
My decks are in a different room in the house and really could do with hearing them through my computer, as well as being able to change the record level.
Ive googled this and i cant find anyone else with the problem, very odd.
I dual boot with Vista 32bit and XP 32bit and its the same in both.
:mad:
