I just installed a Xonar DGX and everytime I shut down an application with sound, I got a 'record stuck' effect that could only be cleared by rebooting. I thought maybe the drivers were corrupt, so i reinstalled them. This didn't help. I went into the BIOS where I had previously turned off the onboard audio, and turned it back on. When I rebooted, the old onboard sound driver popped up in the system tray. This has solved the problem, but now I have 2 icons in the system tray. 1 for the Xonar, and 1 for the onboard audio. Any suggestions on how to remove the o/b sound driver? I can't find it in the Add/Remove programs list. I think I need to completely remove the onboard driver, then disable onboard sound in the BIOS.
My mobo is the Gigabyte Z77X-D3H and the onboard audio driver is the VIA HD audio deck.
Thanks for your help.
