- 21 Oct 2004
- Wales
Need to replace my Xonar U7 but I am having a hard time finding a sound card that supports Dolby Home Theater 4, any suggestions on a replacement that will have support for DHT4?
Great, feature which makes everything sound the same...The balanced intelligent equlizier feature of DHT4, im addicted to it![]()
You missed big pile of stuff to make all content sound the same.I'm not entirely sure what Dolby Home Theater 4 entails, but the blurb points toward what appears to be Dolby Digital Live and probably Dolby Headphone; although those are not actually mentioned.
You listen to that bad music and can't stand it without frequency response being distorted to fit every peg into same round hole?
I would be myself switching music at that point.
That "Intelligent Equalizer" dynamically mangles frequency response of signal to smash all different pegs through same chosen hole shape.
And more things for correcting crap quality of speakers in laptops etc.
1. Normal equalizer doesn't keep changing what it does depending on if input signal doesn't conform to its model of what everything should sound.Im sure that the Creative sound cards use a graphic equalizer .......its the same old crap from the same poster .....If its not Creative it siht basically....been reading his put downs on any sound hardware and headphones that do not conform to HIS taste or likes for a long time and it easy to see he must a creative share holder.
