- 20 Oct 2002
- Surrey
Hi,
Got a Athlon XP 2500+ (Barton) running at 2700+ through an increase in the multiplier, at default voltage. according the the BIOS and MBM5 the CPU is running at about 63c
Is this dangersouly hot ? i'm using the a coolmaster Aero lite, is this a naff HSF ?
- I didn't do it intentionally before anyone comments. Although saying that, it is too high, yes - get a better heatsink (gigabyte g-power pro i suggest if you want a really good result).
