XP-90 and XP90C
depends on the volts, ambient temp, case temp and case flow. Generally it will lower your temps a couple od degrees thou
The XP90-C doesn't fit on all motherboards because of the capcitors. Check with the Thermalright website before purchase.
I've recently purchased one and it does lower your load temps by 15 degrees. I have got a 92mm Vantec Tornado on the top though....and yes it does sound like a plane taking off!!!
The heatsink has got machining lines on the bottom but a tube of artic silver compound will solve that problem.
