XP and ESET
5 Mar 2009
North
I've just built a new computer for my daughter and stuck XP on. It all went fine then started hanging at the desktop, just showing an egg time whenever you hovered over the start or task bar, if you double clicked a short cut it would just egg timer again. So after un-checking bits and bats in msconfig and uninstalling/re-installing drivers and so forth I have whittled it down to eset services. If I un-tick it it boots fine, if I re-tick it it hangs.
Anyone out there have a clue why?
