xp and vista 64
21 Mar 2009
Billingham
can i have 2 o/s in 1 pc? at mo i have vista 64 but need xp to run lineage again, is there a way of doing this?
thanks
richie
You could use Virtual PC or Dual boot by adding another hard drive or partitioning your existing. You need to have XP installed first then install Vista and you will get the dual boot menu. Or you can get programs online to do this for you if you have Vista already installed.
what would you say is the best way is for a noob to do? im not to clued up when it comes to this sort off thing?
thanks
richie
Could use the vista "shrink volume" utility, and create a new partition of ~20/30gig for your xp install, pop the xp disk, reboot, boot from disk and install to that partition.
