xp being wierd
Permabanned
28 Oct 2006
Bournemouth
hi my dads pc is being odd
its runnin xp, the same copy i have now, except his is playing up
basically it will start fine and normal, but sometimes (quite frequently) it will switch from xp theme to the sort of theme you get when you need end an application if it stops respondind, now this isnt such a big issue, but when this happens the sound stops working as well, even though it was working before hand!!!
any one know what is happening, or better yet how to fix, i dont really want to re-format becuase my dad will moan and not do it anyway
That was a 17min bump, SHAME ON YOU!!!!
Btw, I'm having a similar problem with my pc. Does anyone have a fix? <mine doesn't lose sound, just the theme changes back to default>
