Xp boot sequence fails
1 Apr 2006
I suspect I have a mobo or PSU problem.
Today the boot sequence gets as far as the XP logo appearing then after 8-9 rolls across the progress bar, a relay clicks on the Mobo and the system re-boots again (and again...).
Tried safe mode: same result.
Tried booting off the XP install CD, hitting R for repair, but am being told that no hard drives are installed. Also did CMOS reset with no luck. It has run the Intel RAID-1 on SATA1 & SATA2 on the south bridge.
Never tried overclocking the mobo.
Abit IC7-MAX3 "Canterwood" (Socket 478) Motherboard Intel Pentium 4 "Prescott" 2.8GHz (800FSB) with HT
2 x Adata 512MB DDR PC3200 CAS 2.5
2 x Maxtor DiamondMax Plus9 Serial ATA 80GB 8MB Cache
Antec TruePower 430W PSU
YS-TECH FD8125 SILENT 80mm fan - 4 Pin
Sony CRX300E 48x/24x/48x/16x CDRW/DVD Combi Drive
Microsoft Windows XP Home Edition up to date with updates on top of SP2
Alps 3.5" Silver Floppy Drive
Leadtek WInfast A350XT-TDH GeForce FX 5900XT 128MB DDR
