XP Pro, bang up to date on Windows update, not had any new software on in the last week or so.
Did a fresh install about a month ago and everything's been tickety boo. Was using my PC this afternoon, absolutely peachy.
Went to boot about 15 minutes ago and got a missing/corrupt file error. The file C:/Windows/System... is missing/corrupt.
I've got a good experience of Windows and PC's- always built my own etc but never ran Recovery Console before. Did so, it asked what I wanted to do, select the C: Windows bit- it automatically re-booted and--- here I am
I've Shut Down and done a cold(ish) boot to check and all seems well...
BUT.
I had my iPod plugged in and that's caused problems before with slow XP boot times and resets.
Could that have been the problem?
I can't see how the XP files could've got corrupted- nothing's been changed/moved/deleted at all?
More importantly, is there a way to just check now all my key Windows files are safe?
Thanks for any advice
BUT.
