XP Bootcamp Sound Issue?
18 Feb 2006
Installed XP the other day, standard way as I normally do via BootCamp, but it seems that I can only get (bad) sound from the Speakers, and cannot get sound via the headphone jack, nor does the microphone etc work. Regardless if headphones are plugged in, it'll play through the speakers. Googling seems to show it as a problem fairly recently - but no Apple update released, anyone had any similar issues and found a work around? 2008 iMac, if that helps. If it seems that its a problem with the odd install, I could re-install XP and try see if that fixes it - but would prefer not to. Oh, the only difference is I used drivers from the Snow Leopard disk, rather than my Leopard.
Thanks for any help, it's bloody annoying without any sound :p
