11 Nov 2006 at 13:41 #1 dave00 dave00 Permabanned Joined 21 May 2006 Posts 121 Location Newcastle Is there a free program that i could run xp while using vista, Cause i want to use ppstream but it wont work on vista.
11 Nov 2006 at 13:43 #2 tom_e tom_e Man of Honour Joined 26 Dec 2003 Posts 32,596 Location Shropshire search google for virtual pc something useful should come up
11 Nov 2006 at 13:56 #3 dave00 dave00 Permabanned OP Joined 21 May 2006 Posts 121 Location Newcastle Ive found Vmware but im not sure which one it is? Could it be Vmware Player
11 Nov 2006 at 13:57 #4 riddlermarc riddlermarc Man of Honour Joined 15 Nov 2005 Posts 2,124 Location Basingstoke, UK You would need VMWare Server, if you just use the player it won't let you create a virtual machine, just play it. Both are free from www.vmware.com
11 Nov 2006 at 14:12 #5 dave00 dave00 Permabanned OP Joined 21 May 2006 Posts 121 Location Newcastle Oh right i get it Just downloading it now Cheers
11 Nov 2006 at 14:15 #6 csmager csmager Soldato Joined 30 Dec 2003 Posts 5,770 Location London You might be better off with Microsoft Virtual PC 2007 Beta. It's also free, and compatible with Vista. I don't think VMWare is yet.
12 Nov 2006 at 11:26 #7 Berserker Berserker Man of Honour Joined 4 Nov 2002 Posts 15,549 Location West Berkshire VMWare runs Vista just fine thanks, save for that annoying BSOD on shutdown problem with RC2.
12 Nov 2006 at 11:31 #8 csmager csmager Soldato Joined 30 Dec 2003 Posts 5,770 Location London Berserker said: VMWare runs Vista just fine thanks, save for that annoying BSOD on shutdown problem with RC2. Click to expand... Runs Vista or runs in Vista? Because the latter is what the OP needs.
12 Nov 2006 at 11:32 #9 Berserker Berserker Man of Honour Joined 4 Nov 2002 Posts 15,549 Location West Berkshire Ah, good point. I haven't tried it that way around. In that case, the advice about MS Virtual PC seems sound.
12 Nov 2006 at 11:44 #10 bledd bledd Don Joined 21 Oct 2002 Posts 46,890 Location Parts Unknown virtualpc2007beta works fine in vista, been using it all week and its free
