XP "hangs" after startup
15 Jan 2006
Scotland
XP has recently started to "hang" for a few minutes after completing the start up.
When startup is complete I usually go to Outlook Express which is set to automatically check my emails. OE starts up Ok but now does nothing for a minute or two even if I click on send/receive. It eventually goes ahead and checks my emails, but I get a mesage saying that my Firewall is turned off and I might be at risk. The XP firewall is on.
If I try and start IE it will not even start for the first minute or two.
This only happens when I first boot up, if I go back to OE or IE and re-open them all is well. Something is obviously hogging the internet connection and system resources after boot up.
Any advice would be appreciated.
Axel
Is it anything to do with MSN that tries to auto run with OE and IE and would this help?
Start>Run>rundll32 advpack.dll,LaunchINFSection %systemRoot%\INF\msmsgs.inf,BLC.Remove
Could well be!
I installed MSN for visiting kids recently then uninstalled it after they left.
Could you be a bit more specific and clearer in you instructions?
Axel
Click the start button.
Click the Run button.
In the box that appears paste in - rundll32 advpack.dll,LaunchINFSection %systemRoot%\INF\msmsgs.inf,BLC.Remove
Click OK.
