on turning on pc it says "ntldr is missing"
i've tried to use a xp cd and go to windows setup install, but no repair option is available, only the recover console before windows setup,
desperate not to lose all my files on the drive, what can i do?
also can i do a fresh xp install, will this just set up windows and NOT delete ,y files? (but would rather fix the problem, get my files, then re install windows!)
thanks
S
thanks
S
