Just doing my first new build & everything seems to be working until I get to installing windows. I formatted the hard drive and then files start getting copied over. I get to 52% then I get the following message.
<cant remember name> file was not copied correctly.
File setup placed on your hard drive is not a valid windows xp image. If you are installing from a cd there may be a problem with the cd.
Then it gives me options to Retry, Skip or Quit.
I have retried, it didn't work. When I skip it reads a few more files then appears again. It would do this consistently up to 100%.
After that is done I get this message.
I posted here as I'm assuming its a Windoes problem, if its not maybe it could be moved to the appropriate forum. Any help would be apprecited, first build etc.. & worried somethings gone wrong. Any ideas?
