http://docs.info.apple.com/article.html?artnum=303575 said:To perform a right-click action, hold the right Command key while tapping the trackpad button.
Either that or have 2 fingers on the trackpad when clicking, thats how I do it.
I gotta ask, was that not the first thing you tried?![]()
Same as OS X.
Glad you like your new MBP.![]()
how do you scroll then with the mouse pad ??![]()
It tells you that in the system preferences..
"Use two fingers on the trackpad to scroll"
Although you have to enable secondary clicking.
But i dont have a OSX on this MBP pro yet, i do have OSX Tiger disk but it wont install for some reason but i think its because it has a Intel Core 2 Duo 2.33 Chip in it. So will have to insatll panther when i get it.
You installed Windows without booting in to OS X?
I didn't realise it could be done![]()
I think it's been installed via Bootcamp, then the OS X partition has been deleted so it runs Windows natively.
Iirc, he bought it with just Windows on it.
