As title. I have a mate whose Pc which is running XP Home which will only boot up in Safe Mode. If you try to start up normally it just hangs at the XP loading screen. The only other thing that happens is there seems to be the slighest flicker of a blue screen but then goes back to the XP Loading screen.
Any ideas how I can correct the problem?
Cheers
Cheers
Had forgot the Omega's were installed!
