XP Home -> Professional upgrade, any point?
30 Jul 2004
Auckland
Hi,
I bought a system off MM a while back with XP home on it, was doing a clearout and realized that I have a legit copy of XP pro sitting around not doing anything and was thinking about upgrading.
Is there an easier way than a clean install to do it? Equally importantly, is there any point? Have some kind of memory of it having better multiprocessor support, but didn't know if that counted Core2 set ups or not.
I will probably buy a new HD in the next month or two anyway and will probably just wait till then and do a clean install on that.
Any advice appreciated. :)
Clean install was the only way to change i think.
Pro has some more features for a working environment and support for multiple proc's (but both home and pro can handle multi core cpu's)
Basically theres not a lot of difference from what i remember how your using it.
the only benefit for me is the gpedit stuff, particularly being able to assign scripts to run at logon and logoff for the few machines in my house. one to map network drives and the other to run a robocopy backup script
You may as well use Professional when you install a new hard disk if you have it sitting around. XP Professional is supposed to be more stable than XP Home, but there's not really any point in upgrading imo.
I never noticed any difference between the two in general use. Pro has a few more networking features (or rather, easier access to them) but there's very little else. You may aswell use it if you can, but don't buy it if you have home lying around.
Fair enough - thanks for the advice, will leave till next hardware change and then install it then, if I'm not using windows 7 or whatever it is going to be call by the time I have the money for my next upgrade!
pro remembers network passwords, home doesn't
pro has remote desktop, home doesn't
pro can join domains, home can't
^the 3 main differences
home has remote desktop viewer and you can also add full remote desktop into it with a bit of trickery and google if you were really bothered about using it
Indeed you can. You have to do a bit more trickery to be able to be logged on on two accounts on the same computer (one at the computer and one remotely) simultaneously, but that's doable too. It's not officially supported by any Remote Desktop version on any Windows OS though because of licensing issues..
