Better tell all the pc retailers thenBigJon said:err, no it doesn't , aslong as its oem, and the pc has the correct hardware it came with then using the Key on the case is totally legal, - also the key in the recovery disk won't be the key for the machine so technically using the recovery disk is breaking the oem licenceing agreement.
Slam62 said:No thats not legal its got to be the rec overy disc that came with the pc
BigJon said:You should be fine, you might have to ring to activate but you should be fine - also I hope its had a ram upgrade, XP on 256Mb is not fun.
