xp install freezing on 39 mins
18 Oct 2002
uk,manchester
as above im using 2 wd raptors in raid o with an msi k8n neo2 motherboard any ideas would be appreciated.
Try removing any extra cards, just have hte bare minimum installed, one stick of ram or two if needed for dual channel, one optical drive etc
Also go into your BIOS and rest you ESCD i belive its called
Nikumba
Nikumba
do you mean reset the escd to manual? the system is not overclocked thanks for the reply both of you..
