- 16 Jun 2007
- mysterious archipelago
I have just spen the last day trying to get one of my older pcs to start working.
It previously had ubuntu installed and would not allow me to install windows ontop because the GRUB stops it for some reason.
I completely wiped the HD using DBAN
Now i tried to install XP Home SP3 onto the computer and the installed went through fine until it came to the Input your windows cd key
I tryped in the ck key that is on the side of my computer (on the little yellow lable) and it said that my key was not valid!
I recchecked twice i had input the correct cd key but to no avail.
the computer had previously been installed with Home SP2 or very unlikely SP1.But i did not have a installed cd for this so i borrowed a SP3 off a friend.
Does any1 know of any reason why my cd key would not be accepted just because the installed is sp3? is there anyway i can change/alter my key to make it accepted>?anywhere i can find an iso of sp2 to try the cd key with that?
all comment appreciated
thanks
thanks
