Yep, I'm aware that 220 seems to be limit for most of the NF7s (though a lucky few can get them up to 235). Mine is the NF7-S 2.0 (I was warned not to confuse it with the NF7-S2 or the NF7-S 1.0 when I was buying it
), so I should be able to get 220-230 with it. I actually bought it 2nd hand from MM from someone who'd been running it at 227. The only thing I changed about it was flashing it the the D26 Black Mantaray BIOS.
It came with the NB cooler replaced with a passive Zalman,and I've also been guilty of using it as a carrying handle...
It may well be overheating because of this, especially as I'm overvolting it (Baddass clued me in to the bug some of these boards have where if you drop chipset voltage to 1.4 they actually give it more current than the BIOS actually lets you select, and this was how I got it to 220 before the summer in fact). I seriously can't be bothered to take the PC apart though, so I'll only do that as a last resort.
Don't worry too much about the prime 'memory' test - If it's Small FFT stable, and Memtest stable - that's good enough - I never had much luck with the blend tests - not sure why...
I think this must be because Prime wants to test more memory than Windows allocates to it, and so either fails or keeps reading from the swap file and therefore not testing anything since CPU usage is at 30%. When I'm Priming I run a custom test using the blend settings except for testing a lot less RAM (I use 555, just enough to test both chips).
At 200x12 it tested fine for 8 hours last night, but when I tried 210x10 with slackened RAM timings and VDimm upped to 2.7V I still got errors in Memtest (to which I also allocate less RAM than it wants to test to prevent page faults). I've had a sniff about Geil's website and
this seems to be the closest match for the RAM I have. It used to be sold on OCUK but they only sell the Ultra-X and Ultra Platinum ones now, haven't seen this particular one for months. Mine doesn't have the advertised thermometre thingy so it's probably not exactly the same, but it's guaranteed to the same timings. According to that though it's rated to 2.95V, so I'm going to try and give it some more juice, since I'm SURE the RAM's what holding me back. I'd completely forgotten about Geil's lifetime warranty, so I'm no longer bothered about borking it completely! It definitely IS deteriorating since I could get 220 in the past, so might as well speed up the process and get a new set!
try the mem at 2.5-4-4-11 (nf2 didn't like cas 3 for some reason and I found it more stable at 2.5, and 11 seems to give best stability, without causing problem with your hdd's!)
I didn't know it doesn't like CAS 3, nor that 11 is stabler than 12... I assumed that the slacker the timings the more stable it'd be, so I've been testing at 3-5-5-12 (normally I run at 2-3-3-11 and that gives me no problems at stock). I'll try your timings and more voltage for my next test, but what did you mean about problems with my HDD?
UPDATE: Tested at 210x10 with CavemanOC's timings and VDIMM at 2.8 and was a lot stabler, but still produced errors at 250% coverage in Memtest. Don't know if it was the timings or the voltage that made the difference, will experiment more though, maybe risk 2.9, use the bracket, and even reseat the NB HS if I'm REALLY bored!
