XP minimum spec
What sort of spec are you planning on?
I've seen it run on a Pentium 200 MMX, 64mb RAM and at 640x480 - not sure I'd like to see all 3 combined, however! :eek:
it ran on my 233mhz p1 machine with 64mb ram (i think) at 800x600, slow load but runs ok after that. that machine is now just scrap though and just sitting in the corner collecting dust...im too lazy to dispose of it
Don't know hw slow it will go but it ran (just) on a customer laptop which was an AMD K6-2 200 with 32Mb RAM. I wouldn't go so far to say it was useable though!
Basically though as long as it's got at least 196Mb RAM I've found it doesn't matter how slow the processor is. Takes an age to boot but once it's there it's fine.
www.nliteos.com
use that to make it usable on pretty much any pc that you own :)
removes windows components to make xp really lite
edit..
what an idiot, that guy has messenger loaded + themes! -double edit, and Language bar!!!
LMAO
apparently the base specs were about 233mhz and 64mb ram, of course you can run with lower but you dont want it to literally take half an hour to boot up :p this 233 is recommended as its usable (Just)
