Also, I think the OEM license is slightly different in that you can only install it on the one hardware configuration or something.
I thought it was possible to transfer retail licenses from one system to another? Of course you cannot run it on two systems simultaneously, but I seem to remember this was one thing that riled OEM users.unknowndomain said:Although this is true its also the same for retail you are only allowed to install the software on one system at a time and also once installed on that one system it may only be used on that system from the first install onwards. ie. you couldent install it to one system then format the system and install it on another dispite the fact that there is only one system with a working installation on it. (AFAIK)
Al Vallario said:I thought it was possible to transfer retail licenses from one system to another? Of course you cannot run it on two systems simultaneously, but I seem to remember this was one thing that riled OEM users.
What are the differences between OEM and Retail editions?
With an OEM edition of Windows there are certain restrictions in the EULA which differentiate it from the full retail version.
Firstly, the OEM license is said to be ‘non-transferable’. This means that once the license has been attached to a particular PC, it cannot be moved to another, even if the OS has completely been removed from the first computer. The full retail version is slightly different. With the retail edition you are granted one concurrent license. This means that you can move the OS from one machine to another as long as you remove it from the first machine. It also means that you can change the hardware within the computer without it affecting the license validity.
Also, with the retail license you are entitled to free technical support from Microsoft. The OEM edition has support provided by the OEM itself and support may not be complete or free.
