xp or win 7 for old P4
23 Jan 2005
Hi need to install either of the above on parents pc (acer aspire sa85) which has a P4 @3.2 and 2Gb ram what would you suggest.
It will be used for browsing and occasional printing and cd burning.
thanks
Robert
I've used a few systems with a P4 and Windows 7 with 2GB and it was fine. The HD would be the only item I would change if possible though as the disks were old and holding it back the most.
RobTi: If it's a early P4 then it's 32 bit, later ones could use 64 bit but, a long time since I used a P4.
If anything I think I'd put ubuntu on it, but since you only have XP or 7 then go for Windows 7 - could get slow after a while though.
Yeah Linux would just be ideal for his parents. I bet he would enjoy spending ages explaining why everything is different to them.
Ubuntu, this also stops anyone installing virus ridden software, you don't need to install anti-virus.
Not true. Flash & Java drive-by attacks exist for Linux. At least the latest version of Flash for Windows offers automatic seamless updates by default. The same can't be said for most mainstream Linux distros.
Go Win7 32bit.
