Currently I have a dual boot setup with Windows 7 Pro 64 bit on my SSD and Windows XP 64 bit on a separate mechanical drive. To change between the two, I go into BIOS, change the primary boot device and AHCI is changed to IDE (I have several mechanical storage drives in my system). I am quite happy doing this and do not want XP and Win7 to share a physical drive.
I was thinking of picking up a cheap SSD to replace the mechanical drive that XP sits on to make things run a bit faster.
I understand that TRIM function will not work under XP. Are there any potential issues to be aware of?
Main components of my system are:
i7 2600k, Asrock Z68 Extreme7, Samsung 840 Pro SSD, several WD Black 2TB storage drives, 16GB RAM.
I wasn't exactly sure whether the hard drive subform would be more appropriate for this so mods, feel free to move this there if you wish
ok but the question wasn't aimed at you.
