XP pro - Changing Language???
yan
yan
1 Aug 2005
Anyone give any help on changing the language on XP pro pc??
The pc was originally built with XP pro in polish and I want to convert it back to english or have it switchable between englisg and polish. Ive tried changing the regional settings back to english, but this only seems to change the keyboard...
I really dont want to reformat and start again as I dont have all the original hw install cd's... Hopefully it can be done through windows somehow...?
Cheers...
You installed the Polish version of Windows. Therefore, everything is in Polish. If you want English then you buy an English version.
you can do it. i changed my english version in to fully japanese many times.
just have a look around in control panel. sorry i cant help as much
Control Panel
Regional and Language Options
Click languages tab
Click Details
Select English UK from drop down menu
Click add, then apply
Then repeat for language bar and keyboard settings
Bob's your uncle
Hi Monstermunch...
Ive tried changing all the regional settings, but only the keyboard changes..? I have the full english XP pro verision on CD, but I dont have the system disc's for the pc, so wiping and starting again will be a real pain!!
Cheers
It DOESNT work on my friends laptop aswell. He wanted to change the language from japanese to english.
